DC to puls width modulator ( K8004 )
The output of this kit is switched negative,
with the transistor BUK 9535 ( Philips )
I would like to convert this to a positive circuit for a running-light on a motorcycle.
The motorcycle has a negative ground.
Is this possible by repalce the transistor ( BUK 9535 ) into a positive switched transistor.?
if possible, which transistor I supposed to use ?
Ronald.
