My setup:
Running Windows 10 64-bit
Microsoft Visual Studio Community 2015
Version 14.0.25431.01 Update 3
Microsoft .NET Framework
Version 4.7.03056
Applies to VB.NET C# and C++
I have downloaded and manually installed the software components, I successfully ran the x64 test program that came along with the download. I can set outputs and see inputs on the K8061 board with no problem, works as designed.
My issue is when I am writing a program and try to test it, nothing works, I can’t connect to the board. I read through the guide “K8061_DLL_manual.pdf” and my code seems fine, no build errors or warnings. I’ve tried a few idiot checks by looking at the versions of files have been installed:
K8061.dll v4.0.0.1 1,572KB
Driver: K8061Driver_v1.0.0.2
I’m trying to learn what’s going on here because I can’t seem to find out why I can’t connect. What’s a good place to start troubleshooting?
