Velleman K8004 not working at all?
Hello, I bought K8004, it needed soldering, so after I did all what’s needed as shown in the manual. it’s not working, no response at all.
output readings are: 0.01
input readings are: 13 DCv
I tried to play with the trimmers but no luck with making it to work.
Also when I was testing it as mentioned in the user manual, the IC started to heat rapidly.
Please help me I bought 2 and still not working, tell me please what did I do wrong?
please take a look on the images, I hope it to be helpful
Regards.
[quote=“Wrong Way”]It’s very hard to say what’s wrong without being able to see it.
You could put some very clear and sharp picture on a free website and post the link up here so everyone can take a look at it.[/quote]
Thank you for your reply, I added the images as you requested. Your help is so much appreciated.
What are you using for a control voltage?
[quote=“Wrong Way”]Hi,
What are you using for a control voltage?[/quote]
Yes I’m, as PWM.
I don’t understand your answer.
Are you using a PWM as a control voltage?
You really need a DC voltage or you can use the internal reference as shown in the instructions.
[quote=“Wrong Way”]I don’t understand your answer.
You really need a DC voltage or you can use the internal reference as shown in the instructions.[/quote]
Yes as a voltage control, Also I used DC source for input. and it’s still not working.
what I am is going to do now, is to buy a 3rd one and let the store do the soldering for me. So I can see the difference between it and the one I did.
Thanks for your concern anyway.
I’m still not sure of your answer.
For the control voltage you should use a 0 - 10 volt DC not a PWM
If you look at page 8 in the manual figure C you will see a way you can use the internal reference to control the output.
You can download the manual here
http://www.vellemanusa.com/downloads/0/illustrated/illustrated_assembly_manual_k8004.pdf
[quote=“Wrong Way”]I’m still not sure of your answer.
http://www.vellemanusa.com/downloads/0/illustrated/illustrated_assembly_manual_k8004.pdf[/quote]
Ok, I want it to control the RPM of a DC motor. As I know that both a PWM and a voltage control will able me to control the DC motor RPM, Am I right ?
Also, as I tried to follow the Manual I ended up with the board as you can see it above in the Images, So I tried to build it as Figure A.
So tell me please what did I do wrong ?
Thank you.
