Hello Velleman,
I have a HPS5 scope, which is in the new case (same as HPS10-40).
You have answered another forum query regarding serial comms but I assume this applies to the older kit case.
Can you please advise if the serial comms is available with the “in-between” cased HPS5?
The screen displays are the same as the earlier model manual shows. The case is the newer plastic case.
There is a plug in the I/O socket but no connector.
On powerup the screen shows version 9908 under the Velleman copyright notice.
many thanks
