I have to setup a mini lab instalallation which will do the following using a PC:
- acquire some data from sensors. Store. The data is used for some automated calculus, obtaining some outputs values.
- actuate some valves and pumps
Which Velleman products are most suitable for:
- INPUTS
Three analogue inputs, -400 to +400 mV. To be stored by the PC.
2.OUTPUTS. The proces is controled based on programmable time intervals and based on the inputs using:
Up to six outputs (relays ?) for:
- elvalves (12-24Vdc; 1A)
-pumps (220V, max 100V).
I can use VB.
Thanks.
