Hi,…
I like to connect VDPSP151 with VM116. It is possible?
If VDPSP151 is 4 channels, how can I program 4 different switch “binary” positions in the VDPSP151, to control them individualy?
thanks
Luís
Hi,…
thanks
Luís
No One?
[quote]I like to connect VDPSP151 with VM116. It is possible?[/quote]This is not possible. The VDPSP151 is analogue power pack. You need to use DMX dimmer pack e.g. VDPDP152 with the VM116.
Ok,…
I have VDPDP152 with the VM116. The VDPDP152 only have one binary switch.
How can i configure them to 4 diferent channels controled by VM116. The VDPDP152 manual is
Luís
You need just to code the first of the four channels (start address) by the DIP switch.
The four channels are the adjacent channel numbers beginning from the coded address.
