Today, after a though battle. I succeeded in programming the KSR-10 through the existing USB interface with VB NET.
I am currently improving the accuracy of the movements. The biggest problem I encounter is a lack of feedback from the motors and quite a slack in the gearbox’s.
The slack I have almost totally eliminated in the software.
Is there a serious interest in such software, so yes let me know.
Hmm could you make a Dll or anything similiar with an instruction for Programming the Ksr10 Usb Interface. You know the Software is not the best.
And for us all who want to programm the Interface it would be great so we don’t have to analyse the signals every time anew.
Or did you use the original Dll. If yes, could you give us a instruction about the functions written in there because there are no documentations from the creators.
Either way thank you.^^
I did not use any DLL. I hooked VB net directly into the supplied ELAN usb driver. All the internal functions are still under investigation. It is possible to use multiple arms concurrently and it is also possible to destroy the electronics quite easily, just by providing a wrong command. Each command is a separated bit. So the move right bit is a different bit than the move left. This means software-wise that both bits can be set at the same time, resulting in possible damage and blue smoke.
One thing you should do is to remove the batteries and replace them by a double power supply. Because I succeed in quite accurately positioning all the x-y-z-t axis’s and because I control all motors simultaneously, the speed of movement is becoming to dependent on the charge of the battery. Therefore the batteries had to leave.
Futhermore for certain smooth movements the speed of the motors can not be the same. To create a difference in speed, I am pulsing the motors. This makes the movements less sturdy.
Also there is a slack in the gearboxes. This is adjusted by software.
I can let you have some software. I just must find out how I can publish this at this forum and if this is allowed by de moderators.
I currently have added a webcam to the arm. And I am busy to teach the arm to take some euro cents from me and to sort them automatically into different pints.
Also I have a very intelligent cat, which hates the arm. This poor thing wants to destroy the arm. Every time it passes the arm, be sure this happens very cautiously, in hunting mode, ready to attack, and occasionaly the poor robot arm gets a good weck, (a smash) from one of it paws. So I got the idea to program the robot arm to feed the cat. I am ready to video tape this !!!
So stay on this forum, to see more. I 'll investigate the questions I have concerning publishing some software on this forum.
Hi, i’m also very interested in that software you’ve made!!!
Could you send it to my email adress with a small explanation how it is to use? Would make me very happy
THX in advance
Tobias
Hi guys, i’m also interested about the source code of program controlling robotic arm. Are you still up to date with this source? Does anybody have it to upload?
Thanks for help,
Elad.
Hello.
I bought the robot arm and KSR10 KSR10-USB and I want to make a Visual Basic program to handle the robot.
"We could help technicians VELLEMAN? I can not find information anywhere and the truth is that I spent 100 euros in the robot arm and I like to use it with my own VB program
I just need to know the code of how to move a motor, the rest I do myself.
I have KSR10 arm and USB control. I would like to make a VB program to control the chip ELAN. If you can send me an example I would greatly appreciate it.
