Variable infill
Hi @all,
I have created a 3D model of a panel mount frame for the PELI 1120 case.
While filling the actual frame with a honeycomb pattern is good enough, there are certain areas that I would like to be filled 100% because those areas are supposed to hold an insert-nut.
Is there a way to tell CuraEngine to use a 100% infill for certain areas?
Appreciate your thoughts :wink:
Thx, Michael
[quote=ā€œmsprickā€]Is there a way to tell CuraEngine to use a 100% infill for certain areas?[/quote]No actually there isn’t. On the other hand a 100% infill wouldn’t give a good result. Never go over 60%. Foe a thin design like yours it would be better to use an infill at about 50%. the frame will be strong enough as will the nut-holders.
