Values firmware printer
Hello
can somebody post all values or data log from Repetier when we make a M503 command line
because i have change some values and i want to test by returning to original values.
best regards
Hello, sv650s
here’s the output from my “M503”:
06:32:50.224 : Lines Send:1 06:32:50.424 : echo:Steps per unit: 06:32:50.444 : echo: M92 X64.25 Y64.25 Z2560.00 E600.00 06:32:50.444 : echo:Maximum feedrates (mm/s): 06:32:50.444 : echo: M203 X500.00 Y500.00 Z50.00 E500.00 06:32:50.444 : echo:Maximum Acceleration (mm/s2): 06:32:50.444 : echo: M201 X9000 Y9000 Z100 E10000 06:32:50.444 : echo:Acceleration: S=acceleration, T=retract acceleration 06:32:50.444 : echo: M204 S1000.00 T1000.00 06:32:50.444 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s) 06:32:50.444 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 06:32:50.444 : echo:Home offset (mm): 06:32:50.444 : echo: M206 X0.00 Y0.00 Z0.00 06:32:50.444 : echo:PID settings: 06:32:50.444 : echo: M301 P63.00 I2.25 D440.00
Hope, it helps …
Cheers
K1200GT … :slight_smile:
thanks very much
Why is used for X,Y : 64.25step per mm ?
3200steps/1 rotate … used T5 and T05/10 => 3200/(5*10) = 64 step/mm
Why is there in firmware for X and Y added 0.25 step/mm ?
