Utilisation of PCSGU250 under Windows8
I currently use a PCSGU250 oscilloscope under Windows XP
I wish to transfer it on a PC equipped with Windows8
Therefore I downloaded on your site the following packages :
  1. Driver for Microsoft Windows 8
    Works with 32 and 64 - bits versions
  2. PCSGU250 software package, (can also be used as demo version) Rev 1.12
    (released on 15/10/2012)
What is the procedure now to install these softwares and get the PSCGU250 working ?
You can use the instructions written for the Windows 7 driver install.
Here you can download the detailed step-by-step instructions to install the driver: box.com/s/vh9olqyx3idhhxn8ujwm
To install the program, extract the ZIP packager and run the installation program.
To Vellemann support
I applied the procedure described in your post of Tue Sep 17, 2013
I tried both packages available on Vellemann site
pcsgu250_winusbdrv2.zip
pcsdriver-win8.zip
This unsuccessfully
The obtained answer was the following :
“Windows a rencontre un probleme lors de l’installation du pilote pour votre périphérique
Windows a trouve un pilote pour votre périphérique mais a rencontre une erreur en essayant de l’installer
PCSGU250 Oscilloscope/Function generator
Une erreur s’est produite lors de l’ajout du pilote au magasin”
Thank you for your help now
In 64-bit version of Windows 8 you have to disable the driver signature enforcement to install the driver.
Please see:
viewtopic.php?f=10&t=8519
viewtopic.php?f=3&t=9239
