Using VM160T with a VM130 and VM152
Is it possible to program the VM160T-remote that it will works like this:
2 buttons will dedicated to an VM130
The other 2 buttons will operate an VM152
Thanks in advance
VM160 has no relationship with VM130 so we are afraid that this is impossible.
Is there an other possibility to use a led dimmer and 2 relais-output module with one remote?
You could use the VM160T and VM160 4 channel receiver and wire two outputs of the VM160 to the buttons of the VM152.
But The VM160 works on 230V ac.
I only have 14V dc.
Can this work?
Yes, if you remove the transformer from the VM160 and feed it 12-14VDC.
