Using Repetier server with Vertex
I’m trying to setup a Repetier server on a raspberry pi connected to the Vertex.
It seems there is no way to copy the Windows Vertex Repetier printer config to the server http://forum.repetier.com/discussion/comment/612/#Comment_612
and some of the settings seem to have different names so I’m uncertain about some.
Has anyone else tried this (mitch2k seems to be trying too)? I’m a bit nervous about starting a print in case I screwed something up in the settings, although the estimates for a G-code file generated from the Windows Repetier Host seem to produce the same estimates (time, filament etc) when loaded on the server
