How would i set up the board so that I could have a hscrollbar that has a slider that moves in real time in relation to the voltage connected to analog channel one
thanks
thanks
Here is a code snippet how to do it in Visual Basic 2008:
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
VScrollBar1.Value = ReadAnalogChannel(1)
End Sub
i have that code,still dosent work is there any settings i have to change and were do i connect voltage and ground?
Do you get any reading when running the original demo software (.EXE) from the CD or with any other downloaded from here: velleman.eu/distributor/supp … code=K8055
[color=#000080]Software DLL (Rev 3.0.2)
supports Windows Vista, VC++ version and execuatable examples
Software DLL Rev 2
older DLL with examples and source code (source can also be used with DLL rev 3)[/color]
Connect the voltage between the analog input and GND.
