Hi Everyone.
Noob here. I have two K8200’s here - one fully assembled (with a faulty controller(?) board - SMD USB ripped off it) and the other unassembled (and missing some parts).
I have swapped the controllers around - and have the unit (sort of) working, but looking at getting the first controller working again… so I can have two printers.
I noted on the controller board, near the FTDI chip (just above the JPROG connector) is a 6pin header.
Can I assume that this Is this the “mega2560” equivalent to an ISCP port? Can I connected an external 5V FTDI port to it?
Does anyone know, if I connected a 5V FTDI connector to that port, I might be able to bypass the onboard FTDI and use an external FTDI to do all of the communications?
I will save me sending the board away to get SMD port reworked… which I might do anyway - but if I can avoid it - it will save me no end of hassle.
Keen to see if anyone else has done this.
Still learning this platform but thanks in advance.
Mike
BTW: Can I use the latest 2.2.1 firmware on this basic unit? I have Arduino 1.0.6 compile it - but it doesn’t look like its changed the revision past 1.0… thought I’d ask anyway.
Thanks.
