i would like to thank the engineers that have moved forward in bringing forth other oppourtunities and ideas interfacing to the household computers such as this circuitry…
i am thinking about purchasing one of these items but i am looking for a little for info about them…
i am looking to experiment with switching high voltage via computer means… i want a digital output that i can send to a optocoupler to send the signal but isolate it from the logic… i am looking for a module that can send 1-10khz or above… i also want it to have abilities of pulse sequencing… for instants 220,440,880,… pretty much im looking for a logic that is very versetle in its sequencing and frequency… one that can be controlled by code command and eventually create software to control the functions …
the only info i could find that may even relate says “general conversion time: 20ms per command” under specs online… i think this means the delay in response between the control means (computer) and the controlled (usb circuit) 20ms is .02 of a second making it 1/50th of a second… if this is related to frequency of the digital outputs then they are 50hz max.
all help would be greatly appreciated.
