Hi, I’ using a P8062-1 kit to send DMX to a project I’m building. On my project an LED flashes whenever DMX values are received within a certain range. I’ve noticed that if I unplug the USB cable from the Velleman USB board and then plug it back in the LED on my board flashes several times. This would seem to suggest that the Velleman board is sending DMX data when powered up even if no controlling software is running on the PC? If this is the case then it makes the board pretty much useless for use in many shows because as soon as it’s powered up all the lights/smoke machines or whatever are likely to go crazy.
Martin.
