USB DMX k8062
Hmm…
I just soldered the k8062 and inserted the battery to test it but i´m not sure it´s correct.
When i press the test button the power led starts shining.
At the same time the dmx led starts flashing slowly two times. Then the dmx-led starts flashing quickly and remain that way. If i press the button nothing happens. When i then tries to turn it off I need to press it for seven seconds before i powers off.
When i then plug it in the usb my computer finds it and all is well… but when I then start up the light player or any program thats designed for this interface, including my own, the dmx starts flashing again, though a little bit slower than during test mode.
It this supposed to do this. I am a bit worried.
I do not have access to any dmx-apprature at the moment so i´m not able to test the interface but the flashing doesn´t seem good.
I´ve checked all components and all the soldering and all seem correct and fine.
Any clues?
Is it supposed to flash constantly when the program is started. Isn´t the dmx supposed to flash when data is sent. If no data is being sent at the moment there should not be any blink? Am i right?
It seems that everything is OK. The DMX LED flashes all the time when the data is transmitted to the DMX fixture. The data is transmitted all the time when the program is running.
