I have installed drivers, connected usb, lights on the board light up but there is no other response from computer .
Have a look at the [color=#408040]Wiki [/color]for a possible solution.
Did you also connect the 15V power?
If not, the printer won’t respond, cause the board needs to be fully powered to work.
maybe install the drivers again
this
http://www.ftdichip.com/Drivers/VCP.htm
and indeed what ichbin said power supply
and you can use the straight line button on your board to force a connection ( that little button on top right)
And check if you used the correct arduino to compile and upload your firmware
Thats a nasty bugger to
You need arduino 1.0.6 for the newer versions of firmware
with kind regard,
In the printer settings.
Make sure you have the correct Com port selected
The Baud Rate 250000
Reset on connect set to Disabled
