USB connection for WFS210 not work
Hello.
For one project I need collect data from sensors, installed in different places.
I am planning use storage oscilloscopes - WFS210.
When I try connect oscilloscope through USB (connection port - OK, but only for battery charging).
I have some questions.
  1. Can WFS210 connected through USB to PC (Windows 10) not by WiFi?
    Is it possible to simultaneously connect two or more oscilloscopes to a computer via USB ports.
  2. Can few units WFS210 connected through USB to PC?
    Second question. Is it possible to simultaneously connect 2 or more oscilloscopes to a computer via WiFi? And is it possible to configure the network parameters in manual mode?
If there is someone who has encountered such a problem and who can help.
Thanks.
You can capture data via USB.
And connect 2 or more units to an PC.
It isn’t possible to use 2 units by WiFi.
You can’t change the wifi parameters
Hello.
The answer sound good, but reality - opposite.
WFS210 can not connected through USB port.
I am try many times connect with my PC - without any results.
What is solution can be? Without possibility connect to USB - for me it look like “money on the wind”.
Please, give me some solution.
Thanks.
