Is there a component list for the K8200 ?
I am unboxing the printer and wish to inventory the contents.
The K8205 I just unboxed this morning was missing, components advertised as included.
thanks
I don’t think there is a list of parts however if you are missing anything you should contact Velleman and they will send you parts.
If you need any other help you can post up here as well.
Hi @rbeersjr,
welcome to the club.
I had a very similar question when I was unboxing mine.
The component list is there: you need to go through the assembly manual. Every few dozen or so of slides, you’ll see the corresponding bag (needed for assebly) along with the list of parts in it.
https://www.vellemanusa.com/downloads/files/k8200/manual/en/assembly_manual_k8200_uk.pdf
- Page 7
- Page 16
… - Page 494
As @Wrong_Way pointed out, velleman are seing this very positvely, and they’d resend the missing parts to you. Actually, you’llget some spare parts as well. During the assembly, I managed to break this part:
from page 62 from the manual (because you know, you do not know how much force you’ll put when you assemble two plastic parts with some space in between), and I was scared that one will be missing by the end of the assembly, but it turned out that two additional spare parts of this sort were included (only one was needed overall)
Just to avoid some frustration.
When the time comes to adjust the stepper drivers the manual states to set them to 0.425
0.5 is the sweet spot do not go over 0.6 as this will cause them to over heat and do stupid things.
If you are new to 3D printing start with PLA it is more forgiving then ABS and does not put out the nasty fumes ABS does.
