Yesterday i received my K8400 and completed the build.
Today i calibrated the Z axis and tried to load up some filament for my first 3d print.
Unfortunately the print head isn’t able to reach the 245 degrees it needs to reach.
The guide mentioned that it could take a while, but I’ve waited for 2 hours, and don’t think i should take that long?
It stays at around 230 degrees and it wont start loading the filament.
What i noticed is that the top fans keep spinning at full speed, is there supposed to be some control on these fans? or are they meant to blow full speed?
I would really like to get this solved, i want to start using it.
Edit:
Well i managed to get the filament loaded. But it shouldnt work like this.
The steps i did where:
- Manually set fan at 25%
- Manually set extruder temperature to 250 degrees
- Wait for extruder to get to 250 degrees
- Load filament through LCD menu
Because the temperature was above the 245 degrees needed temperature it just went ahead and pushed the filament through.
The first print went great, but the 2nd and 3rd where a nightmare…
The temperature of the extruder didn’t get any higher then 215 degrees after the first layer, so it was only printing some random dots from time to time.
I also needed to use the steps above to get the printing started.
How can i solve this problem?
Best regards,
Danny
