Unable to install driver on Seven 64
I have some big difficulties to install the driver under Windows Seven 64bit.
I have read the workaround and different posts of the forums but still can’t manage to do it work.
I tried to deactivate the win driver signedness verification (bcdedit.exe /set nointegritychecks ON) without success.
It seems that as the driver is not signed for win 64 it won’t install.
Any help would be appreciated
Regards
Et vous avez sélectionné “Installer ce pilote quand méme”?
Bien sur, j’ai effectivement cliqué sur “installer quand même”.
Mais le driver est bloqué, erreur 52, et il apparaît avec un point d’exclamation jaune dans le gestionnaire de périphériques.
J’ai trouvé une solution, mais ce n’est vraiment pas propre.
Il faut appuyer sur F8 au démarrage de windows et démarrer en mode “Disable Driver Signature Enforcement”.
Mais il faut le faire à chaque démarrage du PC. J’ai donc automatisé l’opération avec un logiciel “Driver Signature Enforcement Overrider” trouvé sur ce site: http://www.ngohq.com/home.php?page=Files&go=cat&dwn_cat_id=34
Merci de me dire si il y a une solution plus propre.
The easier solution should be to run the program CP210x_VCP_Win2K_XP_S2K3.exe from the PcLab2000SE installation package: velleman.eu/support/download … 1000&type=
I think you have tried to run this program without any success.
If you run it again - do you see the two Silicon Laboratories programs in the list if you select in the Control panel: Programs / Uninstall a program ?
In this image from the thread viewtopic.php?f=11&t=7203
you’ll see the two programs that should be installed after the CP210x_VCP_Win2K_XP_S2K3.exe is run:
[quote]I tried to deactivate the win driver signedness verification (bcdedit.exe /set nointegritychecks ON) without success.[/quote]It may be good idea to uninstall the bcdedit.exe and the “Driver Signature Enforcement Overrider” software before running the CP210x_VCP_Win2K_XP_S2K3.exe.
When the CP210x_VCP_Win2K_XP_S2K3.exe is successfully run and the Silicon Laboratories driver is installed, the PCGU1000 driver should install and work OK.
Hello, i am new here.
I have the same problem, but i installed the program CP210x_VCP_Win2K_XP_S2K3.exe from the PcLab2000SE.
PCGU1000 don´t run.
When I try to find the driver manually, will not do.
I have a new Laptop Fujitsu with Windows 7 64bit.
On my new Desktop-PC with the same system - no problem - but i must install driver manually over hardwaremanager.
I have uninstall all and try it again, PCGU 1000 is not recognized.
I ask for help setting.
Best regards and thanks!
Please see this thread for a solution:
viewtopic.php?f=11&t=5725
Hello VEL255,
thank you! PCGU1000 works perfect!
