Hi there, have PVM205’5 it works red led always flshes yelow works and green continous. it gets ip from dhcp. and thats it i cant access it in browser, or any thing.
if loading firmware update with the leds like this gaves this:
Device connected
Bootloader Firmware Version: 1.0
Hex file loaded successfully
No Response from the device. Operation failed
Device connected
Device disconnected
Please reset device and invoke bootloader
i tryed to put jumper , shorten reset, unplug usb plug with left shorten but the leds the same, and nothing else, if dhcp switched off then no green led and cant find board it just has 0.0.0.0
rebot button works but the same.
so how any other option i have ?
it looks like reset switch does nothing is there manual shortening on the chip some pins possible ? witch are off them ?
thanks
