Hello everyone,
Here is what I am trying to build : on a laptop, I run a web server (NodeJS) waiting for UDP requests on a specific port 5683 (it’s CoAP protocol, equivalent to HTTP on port 80). On the other side, I have the Velleman Ethernet shield stacked on an Arduino Mega, initialized with UIPEthernet library.
When I wire all these things to my ISP’s modem (a french one), all is working great :
- Arduino gets a IP address via DHCP
- Arduino answers to ping
- Arduino sends UDP packets to the server (I have logs)
But when I try to replace the modem with a standard router (TP-Link TL-WR841N) or a switch (Netgear GS108T), problems appear :
- Arduino can’t get IP via DHCP
- Arduino can’t start UDP connections (udp.begin==false)
- UDP server receives nothing
- Arduino does not answer to Ping
- With different libraires it is the same (EtherCard, Velleman example…)
I also tried a simple Webserver example on the Arduino, working with the modem and not with the router…
So here is my question : what could do (or not do) my ISP’s modem to let the whole thing work? How / By what can I replace it?
Thank you!
