I’m considering of buying a VM201 module, but i have a question.
I’d like to use the vm201 to add more functionality to the eltako system (contactors) in my house.
This system however is set up to use pushbuttons.
What is the setup of the VM201?
When a relay is set, does it stay in it’s condition (bistable relay), or is it set by the software to remain in it’s state until it is unset?
Or can it be set up to have a pulsed output?
i 'm sorry, but i didn’t really find a description of that feature in the manual.
So if i understand correctly it’s possible to make the relays pulse the output in stead of being set on or off the whole time.
Is this toggle function independent of the timer function (week, day,… )?
Pulse output is in fact a very short timer.
you can toggle the output independently from the timer, but if a timer is active the output will also follow the timer.
