Two PCSGU250 on the same PC
Hello.
Is it possible to connect two PCSGU250 on the same PC to use the both function generators with their own frequency and waveform?
Thank you.
[quote]Is it possible to connect two PCSGU250 on the same PC[/quote]I’m sorry this is not possible.
There is no “addressing” for the PCSGU250 devices.
I found this topic on your website: Double PCGU1000 where someone explained a workaround to connect two PCGU1000 on the same PC. Can I try to do the same with my both PCSGU250?
I’m sorry, there is no similar workaround with the PCSGU250.
The USB “address” PID of the PCSGU250 can’t be changed as it can with the PCGU1000.
