Two on a single pc PCGU1000
Is there a possibility of using two PCGU1000 generators on a single PC? via a DLL or otherwise?
(sorry, forgot the subject field in the previous message).
Mikas
Not with the existing system of drivers and application software…
will this function be available soon?
or do you have plans for a two channel version?
I think it might be possible without altering any of the existing sw/fw if you create multiple installations in virtual machines. If you’re using Windows 7 with a processor that supports virtualization you have an advantage in that MS makes available for free an XP-SP3 VM that directly supports virtual USB connections. If your available system doesn’t support that configuration you will have to go with something from VMware or similar. The “low end” VM from MS that runs on anything doesn’t include support for USB, nor does it include any O/S. I haven’t priced it lately, but VMware in small quantities wasn’t absurdly expensive.
It can be done, see this thread (viewtopic.php?f=11&t=1243). It’s not the easiest thing in the world to do, but it’s not rocket science either…
