Two K8060 ' s with a single mixer
I am building two K8060’s in a stereo set up fed by a single mixer. I have seen you say that there should be no common components but does that include a mixer in this type of setup?
Thanks Pete
Should not be a problem if both K8060 have a separate supply transformer.
Make sure to avoid hum loops when you wire your assembly.
