I have recently purchased two vm110 interface boards. Currently i am writing the software for it to control several devices.
I am using K8055d.dll version 2.0.0.1
The two cards are controlled from one thread within the software. I have programmed a continues loop which scans first device 0 and then device 1. Board switching is performed with the SetCurrentDevice procedure.
I have two issues with the cards at the moment which leads me to conclude that the problem might be within the K8055D.dll
Issue 1:
Situation:
Two boards connected. I have programmed within the loop that when button 5
is pressed on card 0 output 5 is set to TRUE. When button 4 is pressed output 5 is set to FALSE.
The code does seperate handling for card 0 and seperate handling for card 1 (but all in one loop).
I programmed the same functionality (press 5 --> output 5 TRUE, press 4 --> output 5 FALSE) for board 1 (seperate piece of code, like if currentcard = 1 then perform the following actions, and if current card = 0 then perform other actions)
The test i have conduced :
I have started the software to continuesly scan the cards.
The following happens.
Press button 5 on card 0 = output 5 on card 0 is true (led is on)
Press button 5 on card 1 = output 5 on card 1 stays false (led stays off)
Press button 4 on card 1 = nothing happens (led is already off ofcourse)
Press button 5 on card 1 = output 5 on card 1 is true (led is on)
I can see i have pushed the buttons ( the software i have written shows it to me)
I tested the button behaviour also with software commands (not pressing the buttons, but just giving the SetDigitalChannel command
Behaviour seems to be the same
Issue 2:
Within the same loop i want to a set the analog outputs also (OutputAnalogChannel(long,long)).
When i do this the next time i issue the command SetDigitalChannel(5) both cards set output 5 to true!
This means that after i have set one of the analog ports i loose the ability to control a board individually.
I am using powerbuilder 10, and one card functions without any problems.
If anyone needs to see the sourcecode, i will post it, but for a first post i thinks it’s a bit much
As requested (the paste looses the tabs, sorry for that):
of_set_check_box:
Card 0
Channel 1 to 8 output : 1 to 8 Set the corresponding output check box in the main window to on
Channel 1 to 8 output : 11 to 18 Unset the corresponding output check box in the main window to on
channel 1 to 5 input : 21 to 25 Set the corresponding input check box in the main window to on
channel 1 to 5 input : 31 to 35 Unset the corresponding input check box in the main window to on
Card 1
Channel 1 to 8 output : 101 to 108 Set the corresponding output check box in the main window to on
Channel 1 to 8 output : 111 to 118 Unset the corresponding output check box in the main window to on
channel 1 to 5 input : 121 to 125 Set the corresponding input check box in the main window to on
channel 1 to 5 input : 131 to 135 Unset the corresponding input check box in the main window to on
boolean lb_channel_0, lb_channel_1
boolean lb_prev_out[16]
integer li_channel_counter = 1 , li_temp
long ll_digital_input, ll_digital_output
long ll_Return_Value
integer li_prev_milli_time, li_cur_milli_time, li_milli_sec_diff
long ll_CurrentDevice = 0
lo_nvo_intfobj.ib_stop = FALSE
li_prev_milli_time = 0
li_cur_milli_time = 0
ll_Return_Value = OpenDevice(1)
ClearAllDigital()
ll_Return_Value = OpenDevice(0)
ClearAllDigital()
lo_nvo_intfobj.of_SpamMessage("Opened devices")
DO until lo_nvo_intfobj.ib_stop = TRUE
SetCurrentDevice(ll_CurrentDevice)
//We get the system time from kernel32 to show the scan interval in the main window
GetSystemTime(s_systime)
li_cur_milli_time = s_systime.millisecond
IF li_prev_milli_time < li_cur_milli_time THEN
li_milli_sec_diff = li_cur_milli_time - li_prev_milli_time
ELSE
li_milli_sec_diff = 1000 - li_prev_milli_time + li_cur_milli_time
END IF
li_prev_milli_time = li_cur_milli_time
lo_nvo_intfobj.of_set_interval_message(li_milli_sec_diff)
//First we check whether a input button is pressed
IF ll_CurrentDevice = 0 THEN
FOR ll_digital_input = 1 TO 5
lb_channel_0 = ReadDigitalChannel(ll_digital_input)
IF lb_channel_0 = TRUE THEN
lo_nvo_intfobj.of_SpamMessage("Button " + string(ll_digital_input) + " pressed on card 0")
IF ll_digital_input = 5 THEN
lo_nvo_intfobj.of_set_check_box(5)
END IF
IF ll_digital_input = 4 THEN
ClearDigitalChannel(5)
lo_nvo_intfobj.of_set_check_box(15)
END IF
lo_nvo_intfobj.of_set_check_box(ll_digital_input + 20)
ELSE
lo_nvo_intfobj.of_set_check_box(ll_digital_input + 30)
END IF
NEXT
END IF
IF ll_CurrentDevice = 1 THEN
lb_channel_1 = ReadDigitalChannel(ll_digital_input)
IF lb_channel_1 = TRUE THEN
lo_nvo_intfobj.of_SpamMessage("Button " + string(ll_digital_input) + " pressed on card 1")
lo_nvo_intfobj.of_set_check_box(105)
END IF
lo_nvo_intfobj.of_set_check_box(115)
END IF
lo_nvo_intfobj.of_set_check_box(ll_digital_input + 120)
ELSE
lo_nvo_intfobj.of_set_check_box(ll_digital_input + 130)
END IF
NEXT
END IF
//Then we check whether we received a message to set a digital output
// This goes on from 1 to 16 (Two Cards)
IF ll_CurrentDevice = 1 and li_channel_counter > 8 THEN
FOR li_channel_counter = 9 to 16
IF lb_prev_out[li_channel_counter] <> lo_nvo_intfobj.ib_outputchannelvalue[li_channel_counter] THEN
lb_prev_out[li_channel_counter] = lo_nvo_intfobj.ib_outputchannelvalue[li_channel_counter]
lo_nvo_intfobj.of_SpamMessage("Output Channel Value = " + string(lo_nvo_intfobj.ib_outputchannelvalue[li_channel_counter]) + " for card 1")
ll_digital_output = li_channel_counter - 8
IF lo_nvo_intfobj.ib_outputchannelvalue[li_channel_counter] = TRUE THEN
lo_nvo_intfobj.of_SpamMessage("Output " + string(ll_digital_output) + " for card 1 set") SetDigitalChannel(ll_digital_output)
li_temp = Integer(ll_digital_output) + 100
lo_nvo_intfobj.of_SpamMessage("Message = " + string(li_temp) + " for card 1")
lo_nvo_intfobj.of_set_check_box( li_temp )
ELSE
lo_nvo_intfobj.of_SpamMessage("Output " + string(ll_digital_output) + " for card 1 unset")
//First we do a set, it seems like the card does not like a set when we send an set message to the other card
// Maybe he is starving for attention
ClearDigitalChannel(ll_digital_output)
li_temp = Integer(ll_digital_output) + 110
END IF
END IF
NEXT
ELSE
FOR li_channel_counter = 1 to 8
lo_nvo_intfobj.of_SpamMessage("Output Channel Value = " + string(lo_nvo_intfobj.ib_outputchannelvalue[li_channel_counter]) + " for card 0")
lo_nvo_intfobj.of_SpamMessage("Output " + string(ll_digital_output) + " for card 0 set") SetDigitalChannel(ll_digital_output)
lo_nvo_intfobj.of_SpamMessage("Message = " + string(li_temp) + " for card 0")
ELSE
lo_nvo_intfobj.of_SpamMessage("Output " + string(ll_digital_output) + " for card 0 unset") ClearDigitalChannel(ll_digital_output)
END IF
END IF
NEXT
END IF
// Then we set the analog channel to the value requested
// Not implemented because there is a problem with this.
// When the analog channel is set then the next time we set a digital channel
// both cards repond to it. And thats not what we want!!
OutputAnalogChannel(1, lo_nvo_intfobj.ii_analog_1)
OutputAnalogChannel(2, lo_nvo_intfobj.ii_analog_2)
END IF
OutputAnalogChannel(1, lo_nvo_intfobj.ii_analog_3)
OutputAnalogChannel(2, lo_nvo_intfobj.ii_analog_4)
END IF
//Now we set the other card active and restart the loop again
ELSE
END IF
//Then we check whether we need to stop
IF lo_nvo_intfobj.ib_stop = TRUE THEN
lo_nvo_intfobj.of_SpamMessage("Stopped scanning the device")
exit
END IF
LOOP
CloseDevice()
//END IF
Please use the ‘code’ button. It will make sure that the original formatting is kept…
If the piece of code is rather large, please post as a link to a file.
