Turn the computer on / off with the mk160 project
Hi how does the mk160 do you dial a number? Can anyone start my computer if i build this.I am going to take out the power switch out off the computer and cut the connector and use the connector as power to the mk160. Is it possible
hi,
I have tried this before with KEMO Electronic’s card switch …
It should work, though the relay would need to only be activated for a second, not permanentaly…
also check that the voltages are the same, they should be, but it might be morth making sure…
best wishes regarding your project
fish
