Private Declare Sub ReadAll Lib “k8055d.dll” (ByVal data As Long)
Private Declare Function Version Lib “k8055d.dll” () As Long
Private Declare Function SearchDevices Lib “k8055d.dll” () As Long
Private Declare Function SetCurrentDevice Lib “k8055d.dll” (ByVal CardAddress As Long) As Long
Private Declare Function OpenDevice Lib “k8055d.dll” (ByVal CardAddress As Long) As Long
Private Declare Sub CloseDevice Lib “k8055d.dll” ()
Private Declare Function ReadAnalogChannel Lib “k8055d.dll” (ByVal Channel As Long) As Long
Private Declare Sub ReadAllAnalog Lib “k8055d.dll” (ByVal Data1 As Long, ByVal Data2 As Long)
Private Declare Sub OutputAnalogChannel Lib “k8055d.dll” (ByVal Channel As Long, ByVal data As Long)
Private Declare Sub OutputAllAnalog Lib “k8055d.dll” (ByVal Data1 As Long, ByVal Data2 As Long)
Private Declare Sub ClearAnalogChannel Lib “k8055d.dll” (ByVal Channel As Long)
Private Declare Sub SetAllAnalog Lib “k8055d.dll” ()
Private Declare Sub ClearAllAnalog Lib “k8055d.dll” ()
Private Declare Sub SetAnalogChannel Lib “k8055d.dll” (ByVal Channel As Long)
Private Declare Sub WriteAllDigital Lib “k8055d.dll” (ByVal data As Long)
Private Declare Sub ClearDigitalChannel Lib “k8055d.dll” (ByVal Channel As Long)
Private Declare Sub ClearAllDigital Lib “k8055d.dll” ()
Private Declare Sub SetDigitalChannel Lib “k8055d.dll” (ByVal Channel As Long)
Private Declare Sub SetAllDigital Lib “k8055d.dll” ()
Private Declare Function ReadDigitalChannel Lib “k8055d.dll” (ByVal Channel As Long) As Boolean
Private Declare Function ReadAllDigital Lib “k8055d.dll” () As Long
Private Declare Function ReadCounter Lib “k8055d.dll” (ByVal CounterNr As Long) As Long
Private Declare Sub ResetCounter Lib “k8055d.dll” (ByVal CounterNr As Long)
Private Declare Sub SetCounterDebounceTime Lib “k8055d.dll” (ByVal CounterNr As Long, ByVal DebounceTime As Long)
Private Sub Connect_Click()
Dim CardAddress As Long
Dim h As Long
CardAddress = 0
CardAdress = 3 - (Check1(0).Value + Check1(1).Value * 2)
h = OpenDevice(0)
Select Case h
Case 0, 1, 2, 3
Label1.Caption = “Card” + Str(h) + “Connected”
Case -1
Label1.Caption = “Card” + Str(0) + “not found”
End Select
End Sub
Private Sub CommandButton2_DblClick(ByVal Cancel As MSForms.ReturnBoolean)
SetAllDigital (0)
End Sub
Private Sub Form_Terminate()
CloseDevice
End Sub
I wil check all digital outputs ( LED on/off ) and test with these buttons:
I have change it but it still not work.
I will make it in a Excel program, when i push the button " Set All Digital " that all Digital outputs are active .( LEDS on )
[quote]Have i also make a button to connect the K8055 ?[/quote]Yes, you have to make it.
Please download the latest software package for the K8055.
Here is the link to download page: velleman.eu/distributor/supp … code=K8055
Download the: “Complete SDK Pack (Rev 4.0)”.
The package includes new K8055D.DLL and sample projects written in various programming languages. - Visual basic and Excel examples are included.
Pleas read the “README.TXT” and the “K8055 & VM110 Getting Started.pdf”.
I’m not sure if this is what you meant.
Here is a script showing the text “Contact Closed” if digital input 1 is connected to the GND.
If this input is open, the displayed text is “Contact Open”.
You can test this by pressing the button Inp1 on the K8055 card.
You have to put on the Excel workbook two buttons (connect and close) and assign them to the macros: Button1_Click() and to Button2_Click().
When connected, the status of the digital input 1 is checked every 100ms using a timer.
[code]Option Explicit
Private Declare Function SetTimer Lib “user32” ( _
ByVal HWnd As Long, ByVal nIDEvent As Long, _
ByVal uElapse As Long, ByVal lpTimerFunc As Long) As Long
Private Declare Function KillTimer Lib “user32” ( _
ByVal HWnd As Long, ByVal nIDEvent As Long) As Long
Dim TimerID As Long
Dim TimerSeconds As Single
Sub Button1_Click()
Dim h As Long
h = OpenDevice(0)
If h = 0 Then
ActiveSheet.Cells(1, 4) = “Card 0 Connected”
TimerSeconds = 0.1 ’ the timer interval is now 0.1 sec.
TimerID = SetTimer(0&, 0&, TimerSeconds * 1000&, AddressOf TimerProc)
Else
ActiveSheet.Cells(1, 4) = “Card 0 Not Found”
End If
End Sub
Sub TimerProc(ByVal HWnd As Long, ByVal uMsg As Long, ByVal nIDEvent As Long, ByVal dwTimer As Long)
On Error Resume Next
Dim b As Boolean
b = ReadDigitalChannel(1)
If b Then
ActiveSheet.Cells(1, 1) = “Contact Closed”
Else
ActiveSheet.Cells(1, 1) = “Contact Open”
End If
End Sub
Sub Button2_Click()
KillTimer 0&, TimerID
CloseDevice
ActiveSheet.Cells(1, 4) = “Card 0 Closed”
End Sub[/code]
[quote]And this text in a Privat Sub Label.
is that posible ??[/quote]I think this is not possible in Excel.
Maybe possible in other programming languages…
Dim old_sw1 As Boolean
Dim old_sw2 As Boolean
Use this timer procedure:
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
Dim sw1 As Boolean
Dim sw2 As Boolean
Timer1.Enabled = False
sw1 = ReadDigitalChannel(1)
sw2 = ReadDigitalChannel(2)
If sw1 <> old_sw1 Then
If sw1 Then
MsgBox("Door = Closed", vbExclamation, "Door")
Else
MsgBox("Door = Open", vbExclamation, "Door")
End If
End If
If sw2 <> old_sw2 Then
If sw2 Then
MsgBox("Window = Closed", vbExclamation, "Window ")
Else
MsgBox("Window = Open", vbExclamation, "Window ")
End If
End If
old_sw1 = sw1
old_sw2 = sw2
Timer1.Enabled = True
End Sub
You can use the demo program in the latest software package and replace the timer function with this one.
You can use the Visual Basic function Time or Time$ to print the time.
Here an example screenshot:
This is the script to print the time:
Dim TimerID As Long
Dim n As Long
Sub Button1_Click()
Dim h As Long
n = 0
Columns(“A:A”).Select
Selection.ClearContents
Range(“B1”).Select
h = OpenDevice(0)
If h = 0 Then
ActiveSheet.Cells(1, 3) = “Card 0 Connected”
Else
ActiveSheet.Cells(1, 3) = “Card 0 Not Found”
End If
End Sub
Dim sw1 As Boolean
Dim s As String
s = Time$
n = n + 1
If sw1 Then
ActiveSheet.Cells(n, 1) = "Door = Open Time: " + s
Else
ActiveSheet.Cells(n, 1) = "Door = Closed Time: " + s
End If
End If
old_sw1 = sw1
End Sub
Sub Button2_Click()
CloseDevice
ActiveSheet.Cells(1, 3) = “Card 0 Closed”
End Sub[/code]
Follow this link to find more about the Visual Basic Time and Date functions: http://msdn.microsoft.com/en-us/library/62dhtt92(v=VS.80).aspx
Here is another useful link for Visual Basic 2008/2010 etc. msdn.microsoft.com/en-us/library/c157t28f.aspx
Please see the links in the section: “Microsoft.VisualBasic.DateAndTime Module”
Thank’s for these link, and other information,
with this information , i can make my experiment complete.
It is for a technical room to check how many times the door opens and close at a day.
