Trouble with k8060 amp
hi i have got a k8060 200w amp i built it did the light test the light comes on i checked all solder joints transformer then it burnt out r5 on the board i got another complete kit bulit it did the light test and the light comes on on that one as well i am new to this and dont know what im doing wrong please help i also checked all solder joints on that board its got me confused all i want is a cheep amp to run my sub thanks
Most likely an assembly error.
hi thanks for getting back to me i have taken photos hear is the link photobucket.com/k6080 hope thay are good enough only got a small camera i did my best thanks not posted photos like this before hope it works new to that as well thanks
Soldering technique looks OK, however, due to poor picture quality, it is impossible to spot e.g. a short or bad soldering.
Component placement looks OK. Unable to see if TIP 142 & TIP 147 have not been swapped? Same for the small signal transistors.
Make sure power supply is within specs.
Use proper heatsink
Make sure metal part of both power transistors are electrically isolated from eachother.
