Trouble shooting HPS140
I am from Germany and a owner of a HPS140. My Problem: It is not longer possible to read any input signal. The display work well. So I have the apprehension that there is a failure in the input area. I don’t know what device is responsible for the failure. It could be the reed relais, the filters, the input amplifier or the A/D-converter. It would be helpful to get a circuit diagramm of the input area. This will help to locate the damage. So is it possible to get this as a PDF-file?
Best regards, Dietmar
No answer? Another example for the contrary way for a good support and marketing.
Dietmar
Sorry, at this time, we cannot trace why this post has not been answered.
We will send you the technical document, but please understand you loose any warranty when you perform repair yourself.
Hello dietmar b., i have the some problem with my HPS140, you can send me the circuit diagramm or service manual.
Best regards, Hector.
Hereby a link to the document.
Please allow 1h for server update.
http://www.velleman.eu/images/tmp/HPS140i%20technical%20doc%20V2.pdf
Thank you.
