Hi
WSAH8060 amp. schematic shows 2 x 30v AC inputs from separate transformer windings.
As one end of each winding is connected to earth, can I use a new trans. that I have which has a centre tapped 60v. secondary i.e. 30-0-30.
Thanks in advance
Hello @Barney,
Yes you can use this transformer (30-0-30), as the the grounds of the separate primary windings (transformer 2 x 30 VAC) are connected together on PCB ( and circuit diagram) => see yellow marked.
Velleman Support
