Transformer for K4003
Hello folks,
I bought a center tapped transformer and I simply want to confirm that this will work for the K4003:
The specs of the transformer are:
. 120v 60Hz
. 2000 mA
. 12VAC - 0 - 12VAC
Thank you for your help,
rc
Should work fine.
That was fast. Thanks.
rc
MCM Electronics sells a toroidal transformer for $16.69.
Torroid Power Transformer 12V x 2.08A
MCM Part #: 287-1040
Multicomp Part #: MCTA050/12
Web site: mcmelectronics.com/product/287-1040
Is this an acceptable part?
I would also recommend a dual ganged potentiometer in place of 2 independent potentiometers if the kit builder wishes to install a volume control as shown on page 8 of the kit manual. (Page 8 shows a connection drawing.)
20K Ohm Panel Mount Potentiometer Dual Audio Taper
MCM Part #: 287-4452 | Alps Electronics Part #: RK27112A00A6
$13.99
mcmelectronics.com/product/287-4452
Dual Gang Potentiometer - Audio Taper 22K Ohm
MCM Part #: 287-2158 | Omeg Part #: PC2G16ECO22KB
$2.79
Web site: mcmelectronics.com/product/287-2158
Transformer looks ok.
