Top Fan is not working 2e day i have the printer running :-(
1e day it works great, now second day not working :frowning:
i have now switch the little fan on te printhead wires tot the other side and put in there place the top fan so its runs while printing
but the litle fan runs not now :frowning:
hardware error or sofware settings?
Connect both fans to the same terminal should work also. Propably tightened the terminal screw to hard and broke of the soldered leg. Might try to solder the pin again and carefully tighten the terminal screw.
This is a diagram of the printhead pcb, like you can see both fan terminals (sk6 & sk7) are parallel connected, so connecting both fans to the same terminal shouldn’t be a problem.
Kind regards
JeAfKe
Thanks JeAfKe
I’ve just been repaired by soldering it again :slight_smile:
No problem glad I could help!
Enjoy the printer.
Kind regards
JeAfKe
