Hi everyone!
I have really big problem in getting the correct dimensions on holes in parts when using slic3r and repetier.
I’ve tried to print with Cuda instead and the inner diameters is much more acurate.
Any one else with similar experiences?
Hi everyone!
The same goes for me. For the smaller diameters I have to make the inner diameter in my design 1 mm bigger. For the outer diameter it’s about 0,5 mm.
I wanted to try printing an object sliced with CuraEngine but my K8200 then starts to do strange things after starting a print job.
This is a common problem that has several contributing factors:
I usually design my models with some kind of “slop” correction factor for all measurements so that I can easily increase or decrease critical dimensions if the test print is not correct.
