Timer reset time
I use the K2579 kit for a alarm installation. The timer is trigered when their is a alarm from a PIR.
When their is after a time again movement detection, I want the timer starts the time from the beginning. The timer open the relay for lights. Every time the PIR detect movement the timer has to start the time again.
Now the timer is not reset and stops after the first movement time is passed.
I want every time their is a alarm the time is starting from the beginning.
Another problem is that the PIR works with NC, this is not working with the timer.
Are their sollutions for this problems?
:exclamation: :question: :bulb:
Not really.
K8015 would be a better choice for the timer, however, you will need to modify the PIR detector so that it features an NO contact instead of NC.
