hi everybody.
my week timer PEREL E305DIN1 was working fine, and now it no longer does.
the connections must be ok since it did work. but now, if I test the output, when the power should go through, either in manual or automatic mode (red light on), the phase output on terminal 5 is cold.
i have used the reset button but to no avail.
is there something inside the timer that can brake? somekind of fuse?
thanks in advance for any insight.
j.
