I’m using a VM201 in combination with pulse dimmer. Now I won’t be able to set timer to switch of the lights due to the minimum pulse of 1 second. The pulse dimmer needs a pulse less than 1 second. How can I solve this problem? Update or something? or can’t be solved?
Switch on the light is no problem…
This is the type of pulse dimmer I use:
