I have a normal K8200 Printer and while i’m printing, something goes wrong and my printed item is in different layers, not matching eachother
[color=#FF0000]Does someone have a solution?[/color]
I was also confrontated with this problem. Each time when I thought the problem was solved
I got a shift at a new cicumstance. But up to now the following actions seem to solve the shift problem
mechanical matters
electronical matters
Software matters
Thank you for the response, i will check these things, it will take some time
[quote=“merallas”]I was also confrontated with this problem. Each time when I thought the problem was solved
mechanical matters
Software matters
i have notes the same problems
al so on the e ax
i wil implement youre sugestions and report
