Hi everyone.
I try to figure out how to test my signal generator. I have only a multimeter. Please someone may send me the good voltage values.
Hi everyone.
You’ll need an oscilloscope to properly test the unit.
If you do not have an oscilloscope, you can connect the output to an amp, to check if it works.
Output level check can be done with a good multimeter set to AC mV.
Thank you for your reply. I checked it in that way. With a non inverting circuit op amp. And it works, because I found at the pin 6, a voltage value around mV (I don’t remember the value).
