Hi, I have a pulsed light machine for my research. I wanted to test the light intensity using PCSGU250. I bought the PCSGU250 from the supplier of pulsed light machine. However, I totally have no idea on how to use it.
Which module should I use as there are some different modules written in the instruction booklet?
What information should I have before I can get the test started? *The light wavelength is within 200-1100nm because it is a combination of UV, infrared and visible light.
What settings/options should I choose for testing? There are many settings like frequency, time/div, trigger, ch 1, ch 2, etc…
If I got peaks, how do I know actual dose of the light?
Thank you so much.
Your help is really appreciated.
