Temperature setting stays 210deg
Finally I’m printing. After a lot of reading on the forum, I’ve found out that the orig. temp. setting (210 deg.) is to high.
I decided to put the temp. down to 190 deg. (in Repetier, configuration, Filament settings, there I’ve changed the print temp. to 190 deg.
After I save the settings and I sliced a object (with the right print config.)
When the printer start, it immediately heats to 210 deg and start printing with that temp. (The print file is on a SD-card).
I don’t understand what I’m doing wrong.
I’m feeling as an enormous newbie :frowning:
Thijs
Yeah, I’m a real newbie.
Stupid me, you also have to choose the right filment profile… :slight_smile:
