[quote]Can I use these sensor for temperature measurement with the K8055 and/or k8061?[/quote]Yes, you can.[quote]If so, what should i do to get there?
Do I need anything else? [/quote]Yes, you need one pull-up resistor (about 2k). Please see this thread for more details: Using a K8055 to take temperature readings
The problem is that the sensor’s resistance variation is quite low. The resistance of the sensor is 1630 ohms at 0C and 3392 ohms at 100C.
You get only rough estimate of the temperature reading anyhow.
