Temperature in Repetier
When I launch the printing, the temperature it’s 210. But in the printer configuration in Repetier I fix it to 200.
The only solution that I find it’s to change manually the temperature in the gcode…
Have you got a solution ?
Thanks you !
Did you change the temperature in the filament settings in Cura? Those override the temperature setting in the printer configuration. (Don’t forget to save)
Yes, it’s the same, M104 & M109 ever S210 …
Strange…
To set it in Cura, look for the configure button on the right under the big ‘Slice with CuraEngine’ button. That is where the real settings are. The Filament tab has the temperature settings for PLA and ABS, and the Print tab has a sub-tab for the G-Codes.
