Temperature control of a small water tank
Hi there,
I have a question about a project I am planning to start working on.
To put it simply, I want to control the temperature of water in a small vessel, somewhere between 30 and 100 degrees celsius. (different temperature/time combinations for different experiments)
I am planning to do this with a K8055 USB interface board.
I plan on heating the water with a basic 220V 1000W heating element (like you find in a domestic water cooker).
For now, let’s assume that I use a relay to control the heater (in fact I am not sure if the result are “smooth” enough or will result in a large sawtooth, but that is a separate issue)
I have seen a K8067 kit, which has a range from 0 to 70C. Is it possible to adjust this to 0-100C??
Moreover, is it suitable to make submersible, or are there other/better possibilities?
Kind regards,
It is not possible to adapt the K8067 for 100°C. Furthermore, it is not submersible.
Sorry, we do not carry a suitable sensor.
wow you have managed to crush all my hope in one reply…
I know it is not submersible… I think I have found some info on how to make a probe with a LM in it (homebrewtalk.com/f51/diy-sub … obe-26400/)
Isn’t there a way to modify the temperature range of the K8067 with another LM?
As I understand from the assembly manual and the the datasheets:
Sensor LM335 is a temperature sensor with a range of 0-100C (national.com/mpf/LM/LM335.html#Overview)
Voltage reference LM385-2.5 has a range of 0-70C (national.com/mpf/LM/LM385-2.5.html#Overview)
What is the function of the LM385-2.5?
Is it only used as a reference temperature (i.e. the ambient temperature?)
The sensor itself seems suitable to operate in a 0-100C range, so why can’t the kit operate in that range?
No suggestions anyone?
In no way we can assist with modifications.
Please note that the LM335 sensor can measure up to 100°C.
Using it at 100°C is just too close to the max. operating range.
Hello soccie49
Maybe you can use a temperature sensor from a car or a motor. They usually have a range to 140 degrees Celsius. Most of them are NTC resistors. When heating them the resistance will decrease.
When you add a serial resistor and connect them to a 9 Volt battery, you can use the voltage over the NTC for measuring the temperature.
You can use analogue input A1 to calculate the temperature.
I hope it can solve your problem.
