Hi!
The extruder temperature sensor appears faulty, it reads only around 145 C and I check the temperature with IR termometer and the extruder was over 200 C. Then I check the resistance in rooms temp and it was 102k ohms, I disconnect the sensor and Repitier still reads 20 C. I have also change the sensor and get the same problems.
Whats wrong?
Regards
Per
