I recently bought a PCSGU250 oscilloscope and am quite new to electronics, so my bad if this question seems silly.
During some testing I discovered that in some situations, inverting the probe points (measuring between A and B and than measuring between B and A) didn’t give the opposite tension…
It occurred when I generated an oscillating tension Vpp = 5V with an offset of 4V. In the first configuration where the “ground” probes matched, I got the right observation on my CH1. But when I inverted the CH1 probe points, my signal is a 0V constant tension.
I realized it actually occurs with every oscillating tension.
I used to work with some other oscilloscopes and I have no memory of this particularity.
I suppose I am doing something wrong, and probably the “ground” probe of CH1 is supposed to be connected to a DC tension.
Can somebody please explain me what I’m doing wrong ? And is there a way to make this oscilloscope work “in both ways” ?
Thanks a lot and have a nice day.
