A few days i am trying to find a way to get this idea to work, here it comes:
I can control my pc with my iphone and it works smoothly. now i want to water my plants just for 20 seconds,
and a few more things working on 12V-- to 230 V ~. like a light etc.
I want to do this from a distance by internet on my phone. so when i would have a menu like that dll shown on some pictures,
i am a happy man.
So i found the new k8090 that could switch 8 relais with a usb signal. and asked the question where the dll could be found, well it can’t because the k8090 isn’t on the marked yet.
i dont know that much of this all as you, (i hope) but could someone please tell me what i can do the best for now.
wait for the k8090 ( god may know how long that’s going to take)
buy the experiment thing (k9055 i think) and a relais kit that can be connected to the k8090.
it would be nice to create a own menu or anything like that for my applications. but i dont know anything of these programms
i have read the entire post and read the manual. this would work to put 8 channels on or of.
but 80 procent of the programm he made is for checking input signals. i dont need any, but for a noob as me just controling 8 channels will be enough anyway.
still a timer function will be nice. maybe it is in his programm but i couldnt find that. neither in the manual.
when i will activate channel 1 ( digital out 1) i think there is 5 V on the output of the 8055 card.
i found this K8015 its a relais with timer function http://www.velleman.eu/distributor/products/view/?id=341552
but it needs 9 V to operate?? so that wont work then.
what i need to do to make the 5 v output to 230 v output.
Normaly i google everything, sorry for al the quistions. its like going 1 step forward and 2 steps backwards when there is a new idea
[quote]when i will activate channel 1 ( digital out 1) i think there is 5 V on the output of the 8055 card.[/quote]There is no voltage output from the K8055. The outputs are open collector NPN transistors. You have to use external voltage.
Here is an example of the connection:
[quote=“VEL255”][quote]when i will activate channel 1 ( digital out 1) i think there is 5 V on the output of the 8055 card.[/quote]There is no voltage output from the K8055. The outputs are open collector NPN transistors. You have to use external voltage.
[/quote]
What about the Analog output ? Can’t I use this to power the relay ? Or somewhere else I can use the 5V from the USB port ?
I’d like to shut down a power supply (switching 220V) with this USB board. But if I have to attach an external power supply to feed the K8055 board… it kind of beats the purpose.
The analog output is not strong enough to drive a relay coil. You can get from it only about 3mA.
[quote]Or somewhere else I can use the 5V from the USB port ?[/quote]You can use this if the relay coil current is <50mA. Connect the +5V from SK2 or SK3 to the CLAMP and connect the relay between digital output and the CLAMP terminal. - Anyhow I do not recommend to use the USB voltage. If you cause a short circuit it may be harmful to your computer.
